Configure Layer 1 and Layer 2 networking parameters for the management port.
This procedure only applies to hardware with a dedicated physical management interface.
The management port on the switch is a 10/100/1000 Mb/s Ethernet port that you can use for an out-of-band management connection to the switch.
Static routes for the management OOB must use the Segmented Management Instance. For more information, see Segmented Management Instance Configuration using EDM.
If you use EDM to configure the static routes of the management port, you do not receive a warning if you configure a non-natural mask. After you save the changes, the system deletes those static routes after the next restart, possibly causing the loss of IP connectivity to the management port.
If you are uncertain whether the mask you configure is non-natural, use the CLI to configure static routes.
- In the Device Physical View tab, select the management port.
- In the navigation pane, expand Configuration > Edit.
- Select Mgmt Port.
- Select the General tab.
- Modify the appropriate settings.
- Select Apply.
General Field Descriptions
Use the data in the following table to use the General tab.
Name |
Description |
Index |
Specifies the slot and port number of the management port. |
AdminStatus |
Configures the administrative status of the device as up (ready to pass packets) or down. The testing state indicates that no operational packets can be passed. |
OperStatus |
Specifies the operational status of the device. |
LicenseControlStatus |
Shows the license status of the port:
Mtu |
Shows the configuration for the maximum transmission unit, the size of the largest packet which can be sent or received on the interface, specified in octets. For interfaces that transmit network datagrams, this is the size of the largest network datagram that can be sent on the interface. |
LinkTrap |
Enables or disables traps for the link status. |
PhysAddress |
Shows the MAC address. |
AutoNegotiate |
Enables or disables Auto-Negotiation for the mangement port. The default is enabled. |
AdminDuplex |
Specifies the administrative duplex mode for the management port. The default is full. |
OperDuplex |
Specifies the operational duplex configuration for this port. |
AdminSpeed |
Specifies the administrative speed for this port. The default is 100 Mb/s. |
OperSpeed |
Shows the current operating data rate of the port. |
